Has anyone had a broken torch control cable? I just broke mine while getting the tabe loaded to cut a project.
Here is a short thread where @ds690 provides a link for a replacement cable
Thank you.
My cutter requires the use of raw voltage, so can I just cut the end off that isn’t being used by my cnc port? It shows to be the same cable.
Yup, should work fine. wiring polarity doesn’t matter since it’s acting as an on/off switch.
It woked great. Thanks.
