Bobcad or fastcam
hi, does anyone use bobcad or fastcam for programming , then importing file into firecontrol?
does anyone have a simple program posted here that can be used to make or modify a postprocessor for either?
thanks
r brintle
@genesibley has .
@rbrintle Welcome to the forum
thanks for the information , do you have a small test program that you can post or send to me so i can try.
my machine is scheduled to be delivered monday the 28th,
Start with the break-in program.
The download is on Langmuir s main page.
There’s a piece of test code here it’s just a simple square with a circle
I have bene using BobCad/Cam V34 for all my programing for a year now, I do both Cad and Cam in BobCad. The Post Processor works very well. You will need to be able to edit some g code. The only thing that doesn’t work is to be able to restart in the middle of the program. For me it isn’t a big deal because I can edit the program to start where I want it to. V30 will work just as well. BC Cam is friendlier than Fusion or Confusion as some call it.
what postprocessor do you use?
fusion 360 is way to confusing and overkill for me
BobCad modified one for me. At no charge because I had the one-year service plan.
