Bendcontrol freezing up on touchscreen
Just got my machine set up today and encountered an issue wherein trying to access machine log, connect to wifi, or access backup / restore screen would freeze up the display (cpu % would still change, indicators for safety buttons /foot switch would indicate as they were pressed) and I was unable to cancel out of anything and would have to cycle power to machine. Eventually I found out that if i disconnect and reconnect the USB plug into the display (on the bottom side in the electrical enclosure) the prompt I was trying to access (wifi connection for example) would immediately come up and work just fine. I updated to the most recent version of bend control via usb and am connected to wifi but problem still persists. Any ideas? All motion control works fine as of yet Ive only jogged y up and down and x + r motors to confirm they are connected correctly.
Any help would be appreciated !
Make sure it has the latest version of BendControl.
Follow the directions to get it on your machine.
Does that version match what @Bigdaddy2166 posted?
Yes, here is of my system which works perfectly.
yes i have v24.1.2 currently installed
