Bar sink drain dimple die
@FlipFlop Just shoot me a message when you’re done with these and ready to send them to their next destination.
@psutex. I’d like to get on the waiting list for these dies as well…
Special Thanks to @nortonscustoms for sharing his information and sharing the dies with this group.
This is the way the internet should work…not sending selfies and bashing others hiding behind the internet.
I have a restored faith in the world.
Well said, and I couldn’t agree more. @nortoncustoms willingness to share the dies has helped a bunch of us out here. I am very thankful as well.
Hang around some. You’ll find lots of good help and fun people here too. It’s one of the things that makes this a nice little corner of the Internet.
Will do. It should not take long.
Well I’m not sure about restoring one’s faith… :grinning: But the mod does help drain the table faster and saves the hassle of climbing underneath to pull the plugs.
Who’s next in line? I am finished with them.
Send me a name and address and I will get them sent off.
I believe i’m next.
Austin Garrod
227 155th pl se
Bothell, WA 98012
I am on a list, but they must be lost, back in Sep
If there is a newlist my name
John Kelly
6915 Pecan Ave
Orangevale CA 95662
Thanks
late to this party, I HAVE THE DIES NOW. life got super busy so i need a few days to use them, then ill get the passed on asap . whose next, JBARK??
see below sir!
this is genius
I do not need the dies now, I ended up going a different direction. There are a number of names on the google doc that are in line for the die.
Thanks John
Where is the list? I will be turning a set today based on @JDE drawing for my table, and can ship out mine when I am done.
All this work with a hole saw, wonder if I just drop my cutter way low and run a cut program…
I believe the XR guys are passing a set of dies around as well. They have a thread with a distribution list.
Well, I made a dual die. One side is for bar drain, the other is the OEM drain.
Should be able to get my drains installed Monday or Tuesday, then I can get these into circulation.
I need to find the guy with the MOD2 OEM drain die. His numbers on the .pdf of the drawing are off. That was fun sorting out.
To cut the hole for the drain, I used the bar sink drain a 2 inch hole. I have put in many bar sink drains and depending on the sink manufacturers i have seen 2.25 inch holes. To cut the holes in the pans i used a 2.5 inch diameter pipe about 3/8 cut off. I welded a tab onto the outside of the pipe to make it easy to hold. Then i used my Hypertherm to cut the hole using the inside of my cut off pipe. It does not need to be perfect. I ground the bottom of pan with 120g and used drains from Amazon, about $6.37 each, Moen. I used plumbers putty and I filled it two days ago and still holding water in the tray.
Well all done, The amazon drain suggested way above SUCKED. So gotta go to Home Depot and get a decent one, Die worked well
2” hole saw through the existing drain worked well
Whose next?! Idk where the list is
Tortilla man want it back…?!?
All I also don’t know where the list is but I would like to get in line if possible…
G Moon 5418 E Florian ave mesa AZ 85206…
Thanks…
@Rug15 - Which one? I found at least two, I did order one of them.
What sucked about them?
