Anyone in poconos
just bought a new crossfire can’t get it to run other than break in , straight cuts and toggle . when a set up a program it tells me there is no tool speed
we can all try to help…we need some information
Crossfire or Crossfire Pro?
Crossfire Pro with THC?
plasma machine in use?
what design and post processor programs are you using?
are you on a laptop or a PC?
Lap top hp v1.2ls. V1.6 . Could it be the torch firing relay . now that I remember when I opened up the relay box it was loose in the box
try a few things here…
run your laptop on battery power only when hooked up and running a program.
Did that this after noon same problem
I do not want to sound rude or sarcastic…
please understand that it is hard to help you if we have to pull information out of you…
please re-read the thread…look at the questions asked…and see how many you answered…
Crossfire no thc or Inc . longevity 40 d plasma . fusion 360 .fire control 20.6.2 v1.6 processor w/o tic or ihs . machine runs v1.2ls . hp Lap top windows 10 64 bit bought this for this crossfire it’s new . I don’t know what information you need if I have to I will send my laptop to langmuire if they want .
I just realized you have 2 threads on the same topic…and you have me looped into both of them…
this thread and this thread you started a couple of hours ago…
and this thread which you started 5 days ago…
each time I asked several times for information…
I will step aside and see if anyone else can help
Sorry I’m just getting frustrated IV been playing wirh this thing for a few weeks trying every thing I can think of
I understand frustration…I really do…
I have sent a link of the other thread to Daniel from Langmuir…he will look into this soon…or one of the other members might have some ideas to help
Thank you for your help
I am in Bloomsburg PA, so not terribly far from the Poconos… unfortunately I don’t know what to tell you with your issue, I’m pretty new to this too!
How is your machine working
I’m still learning as I go but the machine works great!
I’m having problems a bearing race broke on the y gantry and langmuire is also sending a new torch fire port
langmuir working on torch fire issue . anyone i am having a problem with programing the breakin works fine i can run straight cuts but when i make a program and i bring it to the machine it tells me cannot load no feed rate found . i have a crossfire xl v. 1.2ls with fire control v 1.6 processor loaded . also compinsation in control not supported line 235 failed while processing 248
