Amount of stock to leave between parts on 3/8 plate
Cutting multiple pieces out of 3/8 plate, how much space do I need to leave between parts?
If you are making multiple copies of the same parts, a 1/4" setting should be sufficient. When cutting 3/8" plate, be mindful of the duty cycle shutdown on the plasma cutter. Small parts shouldn’t cause any issues; however, if the cutter is running for more than a few minutes, you should be cautious. If you are using a Hypertherm or a larger Everlast plasma cutter, you may not encounter this problem as frequently.
What kind of 3/8 plate?
If it was aluminum I might go a little wider.
And depending on how long the parts are I might change up my workflow a little bit as well.
When I cut long strips of aluminum I have the program nip that’s in off cut in between parts so it doesn’t build up tension and start to Crown the sheet.
Hot rolled steel, set to .50 between parts
