I have a Harber Freight air dryer i would like to install. My compressor is about 50ft from where my table will be located. Should the dryer be at the compressor or at the table?
My first thought is the dryer will be putting out dry and cooled air regardless of where it is located after the air compressor outlet.
I would find the most space-saving and convenient spot for it.
The dryer instructions recommend getting the air temp down as much as possible before the dryer. If you have space on the table end, out it there.
I’ll second that. I’m finishing my dual radiator pre cooler and got a 120 degree temp reduction from the pump side to the tank inlet port without turning the fan on. If I didn’t already have a chiller I’d think about a less expensive option.
Thank you for the information.
