After I create a G code
Hi guys, learning a bunch here thanks to all of you but next issue is can I get back into my sketch after I create the G code ? I can not find it anywhere. I like to use many of the same components on different projects and just wanting to not need to re-draw them each time. maybe there is a way to save portions of a drawing and bring them up as needed ? Would save me lots of time…Thanks.
post an example of what you are doing and I’ll make a walk through of how I would approach the work flow.
For example I have a clock face sketched and I want to put it aside so that I can bring it back up to add different text’s or whatever to the inner part. Seems that once the G code is created the sketch is gone so I can’t edit it without starting over…
bingo!!! you got it Pontiac!
Ok ill do a live stream soon on the scenario. Within the hour likely.
Up 840 MST
I haven’t been on much lately due to ill father. Your sound is so much better.
As always, thanks for the good info and continuing to improve your video system.
Thanks so much TinWhisperer for spending your time to help, I will need to watch this several times while watching on one laptop and following on another but I think it will be a great help.
