I just received my CrossFire Pro and I’m at step 8: Z-Axis Tramming. Per the video, it’s assumed that most everyone’s Z-slide is tilted too far forward. The correction is to turn the adjustment screws on the back inward to tilt the Z-slide back until the Z-slide is perpendicular with the slats.
Out of the box, my Z-slide is already tilted too far back, so I assume I need to do the opposite, which is turn the adjustment screws outward to make the Z-slider tilt more forward to make it perpendicular with the slats. Problem is, the adjustment screws are already loosened to point of falling out of the holes and the Z-slide is not tilting forward at all. Is there something else I need to adjust on the on the Z-slide to tilt the Z-slide forward? Thank you!
