I am almost finished with my MR-1 assembly and I have a few complaint’s along with some praise.
First let me start with the praise:
The first five steps in the assembly process were flawless, the documentation was awesome!
I was a little concerned about the concrete pour but that went great, my experience was basically exactly what the video’s showed. I was the same for the epoxy pour, simply flawless and I was extremely happy with the end results, the base looks awesome.
Now for the complaint’s:
Step Six:
Installing the X-Axis Linear Rails the very first picture shows installing the rails with the “Bright Polished Reference Edges” facing the front of the machine however later in the install process (Step C1 - C2) the documentation states: “When tightening the screws, pull the lower bearing mount toward the front of the machine so that the back precision surface edges of the linear bearings are in contact with the ledge machined into the Lower Bearing Mount as shown.”
This is not possible (unless I am misunderstanding the instructions) as the bearing machined edges are facing forward and the machined edge of the Lower Bearing Mount is towards the rear… I checked the video and you could clearly see the machined edge of the bearings facing the front. In my opinion this portion of the documentation is unclear and should be changed.
The second issue I experienced in step six was an extreme amount of chips inside the X-Axis Gantry, there were chips in the box when I unpacked it so I used compressed air to blow it out as soon as pulled it from the box, but every time I moved it more chips came out, I had a very difficult time installing the gantry without chips getting between the gantry and the Y Axis Carriages. After using a small “magnet on a stick” and compressed air I was finally able to get the gantry set on the carriages with no chips in between. In my opinion this a a bigger issue then the first issue as in my mind this is a QC problem not just a documentation error.
The third issue I experienced in step six was quite a bit of difficulty installing the fasteners between the Y Axis Carriages and the X Axis Gantry Beam, that is a very tight fit. In my opinion if the Y Axis Carriages were just a 1/2" wider (1/4 per side) and the hole spacing widened by the same amount the gantry install process would be much, much smother.
Step Seven:
This was by far the most frustrating issue so far. First the documentation should have you write down the Upper Reference Edge Deviation prior to installing the gantry as it is very, very difficult to read / get a clear picture of it once it is installed (or just move the sticker to the rear of the gantry)
Once I got a picture of the Upper Reference Edge Deviation sticker that I could read I ran the Shim Calculator, the results were six shims on each lower bearing, well this is an impossibility since only 10 lower shims are included. I would really like someone from Langmuir to explain to me how I install sixteen shims when I only have 10??? Worse than that is if you had a worse case scenario in the negative you would need 16 shims… ( I did not calculate the positive worst case) Why would you not include a worst case scenario shim count??? To me this is just plain ridiculous and absolutely should not happen!!!
Here are my numbers just in case there is something wrong with the calculator:
NOD = -.003
TILT = -.002
LEFT = -.005
MID = -.005
RIGHT = -.003
Now I ended up cutting some Y-Axis shims to get the correct thickness, However I have a big concern about this solution as cutting the shims raised a burr that I think will cause an issue…
My only other issue is that the Wireless Jog Pendant (Mini Keyboard) I ordered with the machine doesn’t work, I have opened a support ticket for that today but being a holiday weekend I don’t expect a response until Tuesday/Wednesday next week, I also don’t hold that against Langmuir as that is an outsourced part and they have absolutely no control over QC issues there!!
I guess as a Machinist, Welder, And Fabricator with almost 40 years of experience I find it very difficult to except the shim and chip issue.
That being said, let me be very clear here, all in all, I think the MR-1 is an excellent value and a very well thought out machine, I think the overall design and documentation package is great. With just a bit more polish it would be much better than great…
