Z Axis Not Working Anymore?
I was using my crossfire last night and everything was working properly, came in this morning to cut and my Z axis no longer functions, I can press the up and down on the laptop and it shows on the firecontrol that it is activating that function but no movement of the actual z axis, I can plug it into the x axis and it works so its not the motor or cable. I have reinstalled all the drivers and software and updated the laptop itself and still nothing. Any advice or other things I might try to figure this out would be tremendously helpful as I have ran out of ideas to try.
check the Z axis driver (black box) inside the control box. it should have a green or blue LED lit like the others when powered on. if it doesn’t, then most likely the driver is dead.
Sounds like a potentially dead driver, if you give us a shout at our email support@langmuirsystems.com we can get you sorted out.
Dead driver for sure, thanks for the help! Got one on the way!
