I recently switched to a hypertherm 45xp with a machine torch from my old hobart, and it’s been running fine. Doing my first big production run today, LOTS of aluminum. Was working fine for hours. Now the z-axis can’t lift the torch anymore. If I disconnect the machine torch mount I can get it to run all the way up and all the way down, but as soon as the torch is mounted, I can’t get it further than a 1/16" off the material. Right before this issue it was raising the torch too high on a line even when I turned off THC, like started lifting until I was 1" above the sheet. Finally decided to just move on to a new part, and I can’t get it to lift the torch anymore.
EDIT: I’m dumb, looks like it was just the coupler, I thought it wasn’t because I couldn’t get it any tighter, but it was stuck or something, so I had to loosen the coupler screws in order to be able to tighter them further than they were? Either way, seems fine now.
