I cannot get the Z-axis motor to respond. I have tried manually. On and off the lead screw. I have been cutting for several months and it just stopped today. No buzzing. P I have checked wire connections and everything looks good from what I can tell. Can anyone point me in a direction? Thanks!
Hook up one of the other axis Motors to the Z port( if that’s an option) and see if moving the Z will move that motor.
Good idea. I switched with x- axis still nothing. I would assume it is a wire or a motor issue?
The manual control moved the X-axis motor with the Z-axis controls but the Z axis still doesn’t move using x-axis controls
So your problem of somewhere between the port on the control box and the motor itself. Chase the cable from the plug at the control box all the way up to the motor feeling for any pinch points abrasions or bulges.
Wire seems fine from what I can tell. Thanks for the assistance!
