After instating the THC, I unable to jog it up and down This is one of a couple issues that im having
Anyone have any idea on how to fix this issue
sure we do…but we need some more information
- Was this THC installed on a new Pro table…or an older OG that was upgraded?
- what software are you going to be working with…
- have you downloaded and working with FireControl?
-check all wire connections…sometimes the Z axis wires are not making contact properly
its a gen 2 table with XL Kit
designing in Fusion 360
have been using the table for a year with no issues until after THC install.
I have gone though the wiring 3 times
Try switching the Z motor connection with the X or Y on the control box to see if the problem is with the motor or the controller. If it moves on another controller, then the problem is with the Z motor control in the control box.
will try that thanx
good start @ds690 …
this will determine if your motor is working…
now check In Firecontrol is your “Height Control” in the top right lit up when all connected?
moved the Z axis to another port and it worked great . what would be the cause if it not working in the right port
did you check this
Try moving the X axis motor to the Z connector. Can you move it? Probably not. In that case it has something to do with the Z Axis stepper driver or its wiring.
Something is probably wrong with the Z-axis stepper motor driver. Contact Langmuir support. It could just be a wire that came loose or it might need a new driver.
