Hello,
I have been cutting on my table as time has permitted for a week or so now. Mostly cutting small shapes and coupons to figure out my speeds and amps and lead-ins.
Yesterday during a cut the y2 motor stopped moving and jammed up the table. I first inspected all the hardware on that side of the table and everything looked good. I unplugged the y2 long wire from the control box and was able to jog the cross bar to the back of the table. When i tried to switch the y leads, the y2 motor worked and the y1 motor was froze. I tried several reboots of the computer and turning off and on of the control box with no effect. It appears that something is wrong with the signal coming out of the Y2 port on the box.
Is there anything else i can try? Or is it possible i have a broken control box?
Pulled cover and i have no green light on the black module conected to the Y2 port. Everything else is lit. Yello light flashing on the white board that i dont remember from assembly, but it may have been flashing and thats just my memory.
Send the picture and your explanation to the boys at langmuir support email they will most likely get back to you in a day.
Lojs like a new controller might be needed
Langmuir tech support is fantastic. They had me check a couple things with an ohm meter then sent out a new module for the y control. It was easy to install. I ended up having an additional issue after that and they sent me a whole new control box and paid for postage to send my old one back so they could do an analysis on it. I have been running smoothly ever since. Love my table and can’t say enough good things about how this company takes care of their customers.
Send them an email and I know they will get you going quickly.
Yes i have done all that the OP has done and even swapped out the replacement screws for the plug thumb screws that were provided.
I have the same condition with the green light inside the control box not on. It worked a few times then quit while i was installing the torch and adjusting the cable length.
FANTASTIC…!!!
see there are people out there who like to complain…but then with the right information…and reaching out to them the right way…BANG!!!
