Y2 limit switch open error
While in the middle of a cut program, my XR stops. I called the support line, related the error message and was told I needed a new Motion Control Module in the electronic box. After the agonizingly slow shipping, I received the module almost a week later. I’ve installed the new module and plugged all the connections back into it exactly as before…now getting an error message saying my Y2 limit switch is open and needs to be cleared. I call support again and am told a tiny 2 -pin connector is missing on the upper left corner of the Motion Control Module, once that is put in place I will definitely have table motion again. After putting the connector in place, I have the exact same “Y2 switch open” error message. Has anyone on here experienced this with the XR table?
Have you tried putting an OHM meter on the actual leads coming off that limit switch and testing whether or not the circuit closes when you push on the limit switch?
Didn’t get a chance to try that yet, but thanks for the suggestion! LS advised on how to disable the switches to get motion back, and they’re sending out some of the upgraded switches.
