Y axis, not full travel?
Artfish71,
If you run the Y axis + as far as it will go, then disconnect the lead screw actuator. Move the Y axis to the end, and then screw the actuator to it. I gave up trying to use a center point. Are you saying this will not work? If so, the stepper motor may be faulty.
Brian
