Y Axis Motor Shaft Sheared Off XR
Hey guys, I’ve had my Crossfire XR for about 2 months now it has 3 hours of runtime on it. Today I was cutting when the shaft broke and I lost my cut. I found the shaft was sheared off at the base, a clean break. I assembled the table myself but as some of you might know when you build your XR the gantry uprights come pre-assembled. Not sure what the issue might be besides possibly when Langmuir assembled the uprights, they positioned the motor too far down resulting in too much residual pressure from the belt on the shaft. The belt tension is adjustable by moving the motor up and down and maybe possibly over time the small increase in pressure led to the break. Any information will help. Thanks.
