Can not bolt lead screw nut up without putting it in a bind. I think that the wrong bearing block was installed
Looks like an adjustable block was install where a held one should be and it was loose when I got it
You are definetely correct, that is not right. Sending you a new fixed bearing block. When you get it PM, and i’ll walk you through how to install it.
Thanks for the quick response
