Struggling with fine cut consumables. (OEM) Cut 3 pcs for myself and 2 cut good and one had excessive dross on top and barely cut through. 16ga hot rolled any ideas? Same metal same settings.
Let’s see what the consumables look like, and are they hypertherm brand? Are you using the correct swirl ring and have you swapped out the shield?
I’m running the same setup, I’ve used the Hypertherm Finecuts extensively. I cut at 130 ipm I believe and 40 amps for 16 gauge.
Did you move the work clamp by any chance? I’ve done that……
OEM consumables all fine cut with fine cut shield and swirl ring. If by clamp your talking the grounding cable no I didn’t move it. I just cut some 10ga and didn’t have any issues other than my speed is to low I think. I’ve been cutting on this table for almost a year and never tried fine cut. I’m about to just go back to all process consumables. Waisting a ton of steel with this.
Ok. There’s an explanation somewhere. I’m happy to help you troubleshoot it if you don’t want to go back to standard consumables. A lot of my work requires the fine cuts and I’ve never experienced an issue like yours. Something obviously changed or was different about the third cut. Was it the same file and design?
If you don’t need a .30 kerf to cut your design, there’s no reason to use the fine cuts anyway.
Top dross is a sign that cut speed is too high.
It would be helpful to know the amperage you’re cutting at to assess your cut speed, as well as pictures of how the consumables look to see if they were fouled somehow.
I don’t see amps in any of the photos. Amps is what the machine is set to, not controlled by software.
From your photos you aren’t using the right parts. Fine cuts are unshielded. Nozzle office looks out of round and the tip of the electrode looks bad for only a couple of cuts. But it’s a little out of focus so it’s hard to tell. I’ll snap a pic of mine and the manual in a sec.
The nozzle being out of round will cause what you described. Also explains the bevel in the photos.
Actually if that’s the ohmic shield it should be fine as the tip is still exposed. But confirm the rest of your part numbers.
Also, what is your exact air setup? Filters, dryers, ect.
Hypertherms are internally regulated. Give it 100 PSI and don’t worry about it.
220854 for the retaining cap
220947 for the swirl ring
220948 for the shield
220930 for the tip
For the electrodes
Dude at the welding shop told me these were better
Hard pass. Did you just switch to those? They are a potential problem. You bought a plasma cutter from the best manufacturer in the world. Don’t feed it the cheap stuff.
… and what amps are you setting your machine at?
Totally agree with BrownFox. I used a high rated nozzle that was not Hypertherm and I could tell instantly when it was shot: less than 45 seconds. I could hear it and see the difference in the cut.
The way I tested it was to get my cut doing well. Switched only the nozzle with a brand new knock-off nozzle. First 30 seconds: good. After one minute: shot.
I put the old Hypertherm nozzle back into the stack (mind you - the nozzle had been used for more than 10 minutes of cutting before this test). Perfect cuts. I will never try a knock off nozzle nor electrode again. That nozzle is as important as the electrode: it focuses all of the plasma stream to and thru the metal.
(Note: I have no intentions of trying any consumable other than Hypertherm in the foreseeable future since metal is so costly.)
I know it is a hard pill to swallow when you can get all of this ($4 for an electrode and nozzle):
For the same price that you get 5 electrodes and 5 nozzles that are genuine Hypertherm ($16 for one electrode and nozzle):
But once you see the difference in performance, you will never look back.
45 seconds of usable life for the $4 set = $0.09 per second; or
Easily 30 minutes of cutting life from Hypertherm
$16/(30minutes * 60 seconds) = $0.009 per second.
I’ll try a new one tonight when I get home and I ordered some HT ones. Never In stock locally. Amps are at 40 for 16ga as the book says.
