Hey all,
Im having issues with my XR hitting hard stops. File used cut two times then on the third cut it hit hard stops. I tried rehoming the unit it seemed to take but still will not cut again due to hitting stops. Any help would be appreciated. Limit switches work while homing.
Without more information, it sounds like you need to set work zero to where your piece will fit on the table.
Yes you were correct on this. I cant see a visual because the firecontrol says its not compatible for graphics. After moving the head to the center of the table i learned how to set the work zero thank you for your response.
Also the step for setting this up is mentioned here in case you missed it.
https://www.langmuirsystems.com/xr/assembly#mc4000-setup
Thank you! The graphics seem to be working now.
