Anyone happen to have the specs, I want generate the tool for Fusion or Mach 3. I am guessing I should loosely follow the Cut Chart on the forum and tweak it from there?
The cutting tip/nozzle orifice hole is about 0.95mm and is rated form 20 to 45 amps. So you only have one cutting tip/nozzle to work with. Charts would be real loosely followed, as the Hypertherm 45 (put out more watts) chart would give a lot faster cut speeds and the Razorwed 45 (puts out less watts) chart would give slower cut speeds. Also remember your kerf width will always be 0.95mm orifice hole size and will get wider as it wears…
Well thank you sir for your help
