X45 CNC torch's are here
motorman416@aol.com, mechanic416@georgesplasmacuttershop.com, www.georgesplasmacuttershop.com, 302-690-6995
does that price still stand for Langmuir people?
Yes that price is still good until I sell out of this of this order.
NOTE: I don’t know when I will be getting more torch’s in as Italy is shut down and Tecmo is closed.
Do the consumables for this torch also work on the J45H hand torch that came with my Razorcut 45? I want to be able to use the same consumables for both
Do you want me to it thru your eBay store?
so do you have the “PTM60 machine torch” now? Is it worth it? I’m looking to reduce the taper on 3/16" material. I was thinking fine cut consumables but that might not be the way to go.
I do have it. I bought it from mechanic416 on this forum. I like the fact that the machine torch is clamped above the retainer cup so there is no chance of deforming or wiggling loose during torch head travel. I re-positioned the clamps that come with the Langmuir machine torch holder so they clamp at the top of the machine torch. I also suspended my machine torch hose form the ceiling instead of the supplied arm.
Hi, what are the two little wires off the side of the male connector for?
They are trigger wires for people that don’t have a cnc port on their plasma cutter.
Thank you for the quick response much appreciated.
