Need a little help here. I am have8ng a problem with trying to move the x axis in manual. At 400IPM the motor stops spining and make a wierd noise.
Go back and reset bearing preloads…
Thanks for your comment. I finally got it running.
What was the issue?
The ball screw was not aligned right. Got the lead screw parallel to the x axis and did the bearing preload again. And it is good to go.
Fantastic! Good work! If you edit your post and add SOLVED in the subject line it helps others looking for solutions to similar problems.
Congrats onward and upward!
I took care of that. All set.
I couldnt do it from my phone. Sorry.
