WTB Mach 3 control box
Like the title states, I see a lot of people give them away.
Located in CA.
$200
What all does it consist of IE component specs.
Where are you located?
PP-BOB2-V1 Breakout Board for CNC machining.
3 stepper drives for 3 axes. Two options for stepper drives are available:
Drive 087 generates 1.2-7.0 A phase current.
Drive 484 generates 0.7-4.2 A phase current.
Power supply: Transformer + TL-PSB1 Linear power supply board. Following options are available for the transformers:
Option 1: 42V, 10A Toroidal-CRGO transformer with transformer rating 300VA continuous.
Option 2: 60V, 12.5A Toroidal-CRGO transformer with transformer rating 500VA continuous.
Communication terminals:Serial terminal for interfacing breakout board with relevant CNC controlling PC based software.
Operating interface: External connectors for connections.
Inputs Connectors:
Number of input connector: 1.
Number of inputs: 4.
Emergency input: 1
Outputs Connectors:
Axes outputs connectors: 3 for 3 axes motion control, step and direction output.
Spindle output (VFD output) connector: 1.
Coolants/ relay connector: 1
220V Power indicator: 1.
Emergency switch: 1
Supply voltage: 220V.
Fuse: 2A.
Dimensions: 400x400x130 (in mm).
Weight: 15 kg approx.
I am in Oregon
Ah looks good but prefer to find someone in CA.
I can ship to CA hassle free
