Would I be able to run fire control on a raspberry pi? The requirements say a 1.6 processor and the pi is a 1.5, but I wondered if it would run and I could pull the files from a nas. If anyone has tried would be good to know. Easier to hide a pi on the cutter when I get it then just mount a touch screen monitor and call it a day.
Nope… you need a full version of windows10 not the stripped down Pi version.
Drats. Was hoping.
I like Pie…apple pie…
You can run it with a mini PC and a touchscreen monitor.
But those aren’t 50 bucks.
True, but people are using sub $200 mini PCs. Still not bad.
I just wanted to try something I could hide and would be cheaper. Since It won’t run it will probably just make a long USB and run it from a tower.
I’ve been using an Amazon basics printer cable, 16 feet I think, with one ferrite choke on each end. No issues unless it runs along side the work clamp cable.
I plan on running a DELL Wyse thin-client. It looks like one of those mini-PCs but I can run it over a CAT5. I have my barn wired with a hub and wifi.
I’m using a $89 Amazon mini pc works great
