Was thinking of either making an extension or making a new longer work clamp cable for my cutter. Is there a max length i should be aware of?
Since the torch cable is around 20 feet, I want to have the work clamp cable at least the same length. I want to have my cutter stationary and only move the table when i’m using it but the current cable length is the only restriction right now.
Did you ever make your ground cable longer just curious I’ve been thinking about doing the same. If so how did you do it what did you use etc. I have a primeweld cut 60 thanks
