wobbly torch holder
Hello again! just another thing i was looking at with the new z axis upgrade was the black plate that holds the torch holder. mine is very wobbly and causing really bad cuts. any one else? any have a fix?
If you mean the plate that rides up and down on the rails, the wheels on the right side are adjustable to remove that play.
The end of the bolt that holds the wheels on has wrench flats on it. Hold the flats and loosen the nut. Then turn the bolt to tighten the eccentric cam that the wheel is attached to. Tighten the nut again to lock in the adjustment.
thank you! i was able to figure it out late last night.
