Say what you will, but I need some serious help. This is my first plasma table (crossfire pro) I bought to use around our Hydraulic shop for personal use. Everything’s been pretty easy to assemble, but am I in no way electrician or well-versed in plasma tables. With that being said, I’m stumped on wiring in to my titanium plasma 65. But I’m assuming the red and blue wire when I need to tap into to fire the torch. I’ve literally been doing this all day and I am completely stumped. Anyone have any advice on getting this wired in?
Thank you. Would that be the cable the that crimps on. Im over my head with this wiring. I believe the THC plugs in to the clamp and torch lugs on the back but im unsure it where to put the crimp on wires that i assume are for the torch firing. Am i correct?
Cut the spade connectors off and solder those two wires to pins 3&4 on the CNC connector off the plasma cutter. Polarity doesn’t matter, just one wire to each pin.
I appreciate your help! You saved me a ton of more time tomorrow.
My dude, I provided links in your actual post
