Where should I put my ground clamp on the crossfire pro?
on your material that you’re cutting.
But then the ground clamp will be partially submerged in water or is that not a problem.
clamp to metal…metal sits on metal slats…slats in water…no propblem…
just avoid just clamping to the slats or leaving it in the water…
clamp to material…metter connection less loss of signal through all the parts…
