Ive got Fusion360 and FireControl on my computer. What software should be used to import .dxf files and the like to put into Fusion360 ? I am using a MacBook Air if that helps with which software to upload.
You already have what you need.
Once you’re in the sketch environment of fusion 360.
On the top right bar there is the insert tool.
There you have the options to insert a DXF or a SVG.
Select your file and it will place it on the plane that you have chose which is hopefully it is the YX plane.
thanks TinWhisperer. Its all new to me.
