What is the proper cutting height for a razor weld cut 45
0.06 in with standard consumables. If you’re using a standoff tip (you shouldn’t need to) then you need to drop it to very close to the material as the little protrusions on the tip are about 0.06" themselves. The standoff tip is used for hand cutting resting the tip on the material - the little protrusions (it looks something like a castle) keep it off the material the correct height.
Thanks for your help👍🏻
