How do I know which firmware I have and which cutting software to use?
I just purchased a CrossFire with XL if that helps.
Thanks much.
Tom
Thanks much.
Tom
once you get your table al put together and your PC plugged into it…and you follow the steps slowly and carefully…
you then download Firecontrol from the Download page on the website…it will be the most recent software to use with the table.
https://www.langmuirsystems.com/downloads
the bigger question is…what design software are you going to use…and then…which post processor program are you going to use…
Fusion360 will do design and post processing
Sheetcam only does post processing from any design software…
you just need to install the post processor file from Langmuir into fusion and/or sheetcam
we can always help guide you…
As toolboy says you will want to download the current version of Firecontrol once your table is setup. From there you can flash the firmware if needed.
