Getting clamps for table. What did you guys weld on bottom of clamps to go into table holes ?? Does oil ground drill rod fit in holes ???
Box of 5/8 bolts from lowes.I got longer ones and cut the threads off and left the shoulder.
5/8" mild steel round bar. Weld it on at a slight angle, so your clamp is straight when you tighten it
5/8" shoulder bolts
I don’t have ARCFLAT table so I don’t know if this idea translates exactly, but I used 5/8" and some Harbor Freight clamps for light duty work. Just cut one end of the clamp and weld on the bolt.
I used 3" bolts and PVC spacer as it makes it easier to reach under my table to screw on the nut.
I bought a whole bunch of cheap clamps and welded 5/8" round rod on them…they will fit most tables as most tables are made with 5/8" holes…from cheap ones to nice arcflats…
