Hello. maybe someone can answer this?? In sheet cam the cut path seemed normal… as the tap. file was RUNNING in Mach 3 the torch head moved in circle pattern when transitioning from one cut to the other. It happened one time during the cutting process. It happened on two separate projects. I used the Mach3 no z post processor. I just started using sheet cam, so maybe i have a setting off? or maybe a glitch in mach3???
Or maybe a setting in your Plasma cutter. If you have selected the notorious 4T mode, rather than 2T mode, your torch will never turn off between cuts.
Alternatively you could post your .tap file and people will be able to determine if your problem is with SheetCam or somewhere else.
