Wavy Lines on the XR?!
Anyone seen this? It’s mostly happening on the X direction. As you can see it’s inconsistent, too, adding to the complexity. Any thoughts?
Check torch consumables, what is air pressure to plasma cutter and torch. Have you checked for lose X-axis bearings on carriage?
It could be EMI. Assuming it’s a fusion file and not a file with 500 short lines connected, or a DXF file from the web.
Tell me more about DXF files from the web as an issue please?
Some DXF files are made on programs like (Example) INKSCAPE.
The drawing has 10,000 nodes connected together. When converted, you may have tiny lines connected like a saw blade. That’s my best explanation. Some of our sign guys can chime in.
got it, that makes sense. I zoomed in on my file and it looks like clean arcs and lines in Fusion 360. Thank you.
