Hello All,
I made my first cut tonight and noticed all cuts in Y direction are wavy.
I thought maybe the carriage bearings were too tight so i readjusted all bearings so i could spin them with little effort.
No change.
one of the y axis steppers is alot louder than the other one. I loosened the couplers and ran each motor individually. the motor with the longer cable is defiantly louder. when i rotate the stepper motor with longer cord by hand it feels like it has “flat spots” / grinding.
If you jog the Gantry at say 50 to 100 IPM and lay your hand on the Gantry while moving does it feel rough? This will shed some light on if you might have binding or motor problem
I have had that…I trend to do a complete table clean and lube…
clean rails and bearings
clean drive screws and lightly lubricate drive screws and bearings
check the swirl ring inside torch head…
