Finished water tank install and plumbing on XR, filled table yesterday let sit overnight no leaks.
Wow that really looks good
Thank you.
Just bought the same tank. Are you just running a hose from the pump up to the pan to do the refill?
I have a tee with fitting plumbed into pvc drain line. Attached discharge line from pump to tee and fill through drains of table. green line from pump to tee in pic.
So are you on the mend? Everything went well?
I go in Tuesday 13th., Doc had emergency case come in so I got pushed.
