Water pans rusted
I have scotch Brite pads over drain holes in table. Hasn’t been an issue of crap in tank. The 75-gallon tank under my XR has a 2" clean out cap at bottom if I ever had to clean tank out. All I would have to do is pump tank into water table and remove cap on water tank to clean it.
When I fill water table the additive is bright green as if it is fresh.
Couldnt agree more. These tables are not meant to be drained every day. This is a very uncommon practice.
That’s a good looking set up. Where did you get the tail? Any chance of getting a list of pump, pipe, hoses (all 1–1/2"?) shut of fvalves, and fittings? I’m about to start my XR build, and don’t feel the need to create my own system, and I like yours a lot.
