hey guys, so im curious where everyone is running their water levels in the xr? i did not want to fill all the way to the top due to splashing from plasma so im about an inch away from water. should the water be all the way at the top to have metal in direct contact with water? has anyone cut down their slats to lower bed height?
I run mine to level of flats when cutting steel and 1/2" below Slatts when cutting aluminum. You will get a lot less water splash if you use Slatts that are notched. Cut these for my pro table, will do my XR table soon. The slats cut splash by approximately 60%.
oh wow very nice, thanks for sharing. can you post a picture when you do your xr?
Yes I will, be a couple months just had neck surgery.
