Warm Up Time Discussion
What is everyone seeing as the time it takes to warm up to 375 degrees for example?
They state it heats up quickly, but I’m seeing any where from 20 to 30 minutes to get to temp during the warm up phase.
Anyone else?
Mine gets to 400° in maybe 10 min.
Wow, I wish it was that fast.
Check the heat coil leg with an amp meter. I am not at work till Friday. I will check mine, and we can compare. It may be a voltage issue or a bad heat coil.
Tried to read the voltage at the coil terminals, while it was in the warm up process. It sparked and I could not get a reading. Took the cover off the pro electronics case and read it at the relay and it was 212.5
That is a low reading for voltage. It should be around 240V. We need to check the amp reading to see if the coil is working correctly. Please be careful. Check the voltage reading at your service box while it’s warming up and then again without it on. It may be a wire size on that circuit issue.
That might be a bad coil connection. Send me some pictures of your heating element and the wires that connect to it to support@langmuirsystems.com
Check the wire connections to the heating coil. Might be a bad connection and slowing warmup times. I also had an odd situation the other day where it was taking forever to warm up. Screen was reading 250F but when I opened the oven my part was blackened and the thermometer gun was reading 550F on my part. I restarted the machine and it seemed to be to running normal. Not sure what that was all about.
