Wanted! đź‘€ Fonts rotated vertical fonts. Let's Share
Let’s Build a Collection of Vertical Sign Fonts – Share Yours!
Hey everyone! Let’s work together to create a collection of fonts perfect for vertical signs. These fonts are typically designed so that when the sign is laid on its side, the letters are rotated and positioned on their left side.
If you have or know of TTF (TrueType Font) files that fit this style, please share them here so everyone can benefit! Since this forum doesn’t allow direct TTF file uploads, you’ll need to place them in a folder and zip them before posting.
The goal is to make it easier for anyone designing vertical signage—whether in Autodesk Fusion 360 or another software—to have access to great fonts.
Drop your recommendations, font names, and zipped files in the thread. Let’s build a great resource together!
I’ll start the sharing / collection with these few rotated vertical fonts.
rotated-vertical-fonts.zip (182.5 KB)
AezOutline Vertical-Idle.ttf
Blocky Sideways-BOA3.ttf
BungeeLayers Rotated-Inline.ttf
BungeeLayers Rotated-Outline.ttf
BungeeLayersRotated-Regular.ttf
BungeeLayersRotated-Shade.ttf
vertigo.ttf
here is how i use them in Autodesk Fusion
Using the text on a path function in conjunction with rotated or vertical style fonts works well.
Here in the screenshot I have an arrow pointing to the text along a path. I have a vertical construction line as my path and I’m using these rotated vertical texts on it.
character spacing also works to increase the gapping between letters in this position.
I see what you mean that these are a bit difficult to find. I tried finding them last night on several “free” font sites and came up with noting. I did find a good one but it was $90 for a set of a dozen variations of the same font or $9 per variation. Since I was not needing their font at the time, I passed it by.
I very much appreciate you sharing the fonts you have and will reciprocate if I find any others. Thanks for setting up this topic.
I’ve had a very difficult time trying to find this type of font. The one thing that makes it very hard to search is there’s not really a category or a keyword for this style of font yet as far as I can see. Was trying to search all kinds of keywords like rotated, vertical, 90, sideways, onside, etc and had very limited results.
This poses a good question though what would be a good name for this category of font?
I like “rotated” or “vertical”
If you search for sideways there seems to be a font named “sideways” that dominates the results. Which, just seems to have a bit of a slant to it. All in the eyes of the beholder.
It would all be resolved if Fusion built into the text editing the ability to limit the spacing between lines.
this would be the answer to a lot of design hiccups.
If only Autodesk fusion did…
I was trying to “pattern” text but Fusion won’t allow you to use text as a feature to pattern. This option shows a work-around:
f360vtext
Copied from this page:CAD Forum - Multiline and vertical text in Fusion 360 sketches.
Edit: I just tried this method…I found it very difficult to get everything to move correctly. I could get them to align but moving them correctly to vary the spacing was another issue.
And here is a vertical font generator that has a trial option and then purchase, if you plan to do lots of this:
