I got my cut60 and machine torch in the mail so I figured I’d burn some time making a little cart for it to slid under the machine and also wheel around when I’m using the hand torch.
Still have to add some wheels. If math works like I intended an 8in wheel in the back, the front legs will be perpendicular to the ground.
Still a few things to add and finish welding but thought I’d sare.
I have high hopes, every thing iv read has been positive. I went back and forth between it and a 45xp but with almost a 2k price difference apples for apples I ended starting with this one.
@Natemade what machine torch did you get? i bought a forcecut 40 for my pro table, would like to get a machine torch so i can leave it hooked to the table if i want to use the plasma to make a cut outside or away from the table.
