Viper cut 30 consumables
Considering how expensive consumables are, I was wondering if any of you have tried the off brand ones. Amazon has some with double the amount of pieces for half the price of the RazorWeld ones. Less expensive because they’re junk?
Hit or miss
I have good ones and very good ones. Let me know if you want any
I got mine from Gamble and happy with them so far!
can you get consumables for thermal dynamic SL 60 torch?
I can look and see what i can find
I have same torch and get them from local welding supply shop.
i’m also looking for consumables find these 2 on ebay. what you guys think ?
https://www.ebay.com/itm/0-8-Cutting-Tip-S45-Electrode-Trafimet-consumables-Vipercut-Razorweld-More/323506018781
$23 good deal or you get what you payed for ?
https://www.ebay.com/itm/S45-S54-Part-PD0116-08-PR0110-Trafimet-Air-Plasma-Cutter-Torch-Consumables-21pcs/401119598776?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D2c6d763736234d5a807aa2a39f6b2f7a%26pid%3D100005%26rk%3D1%26rkt%3D1%26sd%3D323506018781%26itm%3D401119598776&_trksid=p2047675.c100005.m1851
Apples to oranges.
The top listing is mine and they are trafimet made in Italy consumables. The bottom ones are not. I do offer both kinds. The non Italian ones I sell a 10pack for $15 of tips or electrodes
Perfect Pual i know they are not same so when you compare yours with Vipercut original one’s are they same ? price different is only $5
also i want to ask you should i try 0.6 orifice one ? i mostly cut 1/8 mild steel does it help on fine cut ?
I can’t say I’ve tested them side by side and I dont know who makes the RW branded ones but I know the company I get them from is solid and that’s all they do is plasma. However being that these are on machines with no height control and most people don’t have air dryers and cut height is the same as pierce height and and and and I don’t think you would notice much of a difference. You might but you may not.
The 0.6 I would use for fine art detailed stuff. Can you use it on 1/8" sure, but if it’s not detailed I’d stick to a .8 tip
