Anyone know where I can get a Mach 3 post processor or help creating one for vectric aspire? I want to use my Crossfire for simple metal home and yard decorations so i really don’t need or want to learn Fusion 360. If i can find a post Aspire will do all i need.
Thanks
Try this site it may be helpful
Thanks John. I’ll look into this. Hopefully it is not above my programming abilities which are nil.
It shouldn’t be too hard, not many commands in the g-code & m-code for this machine there is a list in mach3 of the codes used. Also you can open your .tap files with notepad and look at the code and get an idea of what commands do what.
Using sheetcam and Aspire is really easy.
Export your file as a .svg file.
Open sheetcam and import the file. 2 minutes you have your .tap file ready to cut.
Best setup there is.
Thanks. I’ve downloaded SheetCAM and looking into it.
