FireControl leest geen TAP van “oude” Mach3. Welke software moet ik downloaden?
Firecontrol can not use G code made for Mach3.
You need to post process your files again, using the Firecontrol post processor that is available on the downloads page of the Langmuir website.
You will need to use either Fusion 360 or SheetCAM to create the gcode file. If using SheetCAM it will create a xxx.TAP file. (Fusion 360 produces a xxx.nc file)
Here is the link where you would download the FireControl post processor that SheetCAM needs. Notice there are two versions. One is for a table with the active z-axis (torch is positioned up/down with a motor). The other version does not have an active z-axis.
Thank you for your responce. I already downloaded these files. But I wil do this again.
HR Jeannette
You must take your original designs and run them through the CAM process again, using the Firecontrol post processor, to produce new G code files.
There is no way to convert your Mach3 files to work in Firecontrol.
Thank you for your responce ds60
