I purchased an LS motor mount design online and imported all 4 parts (will be 7 total cut since 3 will be cut twice). The DXF import brings each on in, in this elaborate way where each is it’s own world. what I’m wondering is if I should change the way they are before I try to run them. Should I bring them all into one sketch? Just cut and paste???
Thanks so much, it’s always helpful just to watch you work. I had no idea I was missing the range command.
Also, I don’t think I have the insert DXF in my free version. So I downloaded a utility to download/import DXF’s. but I see it has a bulk import that might have done what I wanted. I’ll give it a try.
And sorry for the mangled original post. It sounded right in my head.
Here’s the actual part. the idea is you buy the pipe portion with bushings in it and attach all this to it. however, the diameter of the DOM tube on this is 1" and I’m going to need 2", so I have to make some changes. And, the supports that go on the engine block side are too close together for strength. Have to change that too. But it’s always easier to have a start.
