Noticed .f3d files can not be directly uploaded to this forum. Is there some restriction on this? I searched forum and did not see anything on this. Would help to get help with issues that can only be duplicated in F360… instead of dxf files… like components with joints.
There are some file restrictions, but, when you run into it there are two options:
- ZIP up the file and upload it that way, or,
- add a .dxf extension to whatever file you’re uploading, eg, blahblah.f3d.dxf will do it. Pretty much everybody knows to remove the .dxf extension.
Thanks… That works well enough.
