Hello all, I am new to plasma cutting and this is my first post, but I have learned a lot already reading through various threads. I’m hoping that someone can point me to a solution here because I’ve made all adjustments that I generally understand. I am getting unwanted gouges in the edge of the slot on the end where the lead in and out are. I attached an image of the programmed path for reference. The material is 11 ga hot rolled, feed 100 ipm, cut height .06" pierce height .160", pierce time 1 sec, air 70 psi, Razorweld 45 @32A. I see this effect in other inside cuts as well but not as pronounced as in this narrow slot. I’m sure it’s a common thing but I’d love a clue before I cut a bunch more parts. Thanks in advance for any insight.
@Itsallgood welcome to the forum
How wide is that slot? Sometimes a shorter Pierce height can be helpful. Or in some cases you may have to make a larger circle or some kind of geometry at the end that you get started from.
Are you using a lead out?
After more experimentation I came to the conclusion that the smallest width cut I can make with my Razorweld is ~1/8", which is fine I guess as long as I’m aware. That’s the size hole it leaves at the end of a line cut. I did use a lead out in the above cut same as the lead in, that’s where the over-burn is. I even manually edited the G-code to turn off the torch prior to a lead out move but it looked like the torch stays lit as it ascends even if it’s turned off. It is odd though, that even when the lead out terminates in the center of the slot, it burns to one side more than the other. It may have something to do with the left side cutter comp but the programmed ascent location in the code is dead center of the slot. For now, I’m content with sticking with >.13 wide features until I get more experience. Thanks for chiming in.
