Hello All!
In the picture, I have three pieces cut. The first piece cut perfectly, on the second you can see it is a little close to the right, but not unusable. The third piece cut is very off. These were all cut in the same “row”, one right after the other. I have a picture from the plasma table with two other failed cuts, all of the failed cuts are different. I cut on the same sheet before with other pieces and had no problems.
I tried new consumables, changed the beads in the 3-stage air dryer, new .nc file, and all my rails are clean and unimpeded.
Has anyone run into this same problem? I am at a loss for what could be causing this and need to consult the hivemind! Any ideas are welcome!
